Edited by choonhong, 26 May 2011 - 11:50 PM.
Helps Needed (Urgent )
Started by choonhong, May 23 2011 10:05 AM
Posted 23 May 2011 - 10:05 AM
deleted
Posted 23 May 2011 - 06:48 PM
It is NOT "invert transformation"; it's inverse transformation. Do you know what a Laplace transformation is? Well, an inverse transformation is the reverse of a Laplace transformation. Just like an integration is the reverse of a differentiation, or antidifferentiation. Let's see how we do on this before we take on erfc.
Guidance Needed For Sizing A Knockout Drum With Multiple Psv DischargeStarted by Guest_fmalik_* , 04 Dec 2023 |
Type Of Scrubber Needed To Remove Hcl Venturi Or Packed Bed ?Started by Guest_pckr9386_* , 13 Oct 2023 |
Typical Design Parameters For Atr Sizing- Help NeededStarted by Guest_daraj_* , 28 Jan 2023 |
Lhsv-Correct Interpretation(Inputs Needed)Started by Guest_daraj_* , 14 Oct 2022 |
Modeling Acid Gas Burner - Help NeededStarted by Guest_daraj_* , 23 Jun 2021 |
