Temperature Change Through A Duct
Started by nathandoog, Jul 18 2011 04:18 PM
Posted 18 July 2011 - 04:18 PM
I would like to know how you go about calculating the temperature of air inside a duct at various locations along it, say you have a duct with 600C air flowing through it at 2430CFM and want to know the temperature of the air 10 ft down the duct. Any help that is given would be highly appreciated.
Posted 20 July 2011 - 12:52 PM
Dear Mr. Nathandoog,
You have given air flow rate and its temp.Only with this data it is impossible to calculate temp.drop along the duct .
The followig informations are missing:
1.Duct shape and size.
2.Ducting material.
3.Insulation.
4.Outside temp..
2.Ducting material.
3.Insulation.
4.Outside temp..
Posted 20 July 2011 - 07:57 PM
Generally, compressible fluids cool upon hydraulic expansion (because of the drop in pressure). This is the case for air.I would like to know how you go about calculating the temperature of air inside a duct at various locations along it, say you have a duct with 600C air flowing through it at 2430CFM and want to know the temperature of the air 10 ft down the duct. Any help that is given would be highly appreciated.
Besides, if you consider heat exchange between the duct and its environment (non-adiabatic flow in the duct), heat loss will additionnaly reduce the temperature of the fluid.
On the other hand, heat gain will obviously increase the fluid temperature.
You might find a complete solution to your problem in any textbook on Heat Transfer.
Edited by sheiko, 20 July 2011 - 08:03 PM.
Posted 23 July 2011 - 03:36 AM
Attached "pipe.xls" is a try to give a way to estimate inside air temperature along the duct. Steady state and simple case was considered, without heat exchanger or expansion. Estimate does not seem quite easy, hopefully the present helps.
Column Bottom TemperatureStarted by Guest_suphaklitwd_* , 05 Oct 2026 |
Electric Heat Tracing—Pipe-Wall Temperature Vs. Actual Fluid TemperatuStarted by Guest_zamakaze_* , 20 Sep 2026 |
Hydrate Temperature Prediction CalculatorStarted by Guest_Wayne_* , 19 Aug 2026 |
Design Of High Temperature Duct WorkStarted by Guest_tjsegan_* , 15 Jun 2026 |
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
