Hi all,
I am Operations Engineer, working under Utilities & Sulfur Complex facilities. I have Demineralization Plant with the arrangement, ACF->Cation->Anion->Mixed Bed vessel, with the capacity of 140 m3/hr; the problem is we experienced resin loss to Pit, during regeneration process.
I am wonder whether you guys have a method/s on how to measure how much anion & cation ion exchange loss in the Mixed Bed. The resin is only 1 yr old. I think by pursuing with total change-out is not that economical + wise to do so. I was thinking of manually check by, backwash and/or air scour -> let them settle and open the manhole and manually check the level of each resins?
Do you guys have any ideas/experience to share?
Hameran
How To Best-determine Which Resin Loss In Mb?
Started by mhameran, Aug 24 2005 04:48 AM
Posted 24 August 2005 - 04:48 AM
Posted 26 November 2006 - 06:25 AM
Dear Mr Mhameran,
You need to instal a resin trap in your system.Also look for any fines in your resin bed. Please check with your plant supplier.
S.Chittibabu
S.Chittibabu
QUOTE (mhameran @ Aug 24 2005, 04:18 PM) <{POST_SNAPBACK}>
Hi all,
Hameran
Hameran
Posted 28 November 2006 - 05:17 AM
Dear Mr Mhameran,
One way to find out the amount of resins present in the bed is to know the quantities of acid and caustic needed to regenerate the resins after exhaustion and separation. From the quantities of acids and alakli used for regeneration, the quantities of resins in the bed can be calculated. If you have the quantities of resins loaded initially, the difference would give the loss.
P.K.Rao
P.K.Rao
Need Help To Determine Axis Orientation Of Lithium NiobateStarted by Guest_Petek_* , 09 Feb 2025 |
Aspen Plus - Is There A Function To Determine The Relative Quantites OStarted by Guest_EdJones90_* , 11 Sep 2020 |
Propane Loss From Sphere TankStarted by Guest_rasprocess2026_* , 04 Nov 2024 |
Pressure Drop Due To Entry Loss At Liquid And Gases Inside The ColumnStarted by Guest_SANDEEPCH_* , 24 Oct 2024 |
![]() Manual Depressurisation - How To Determine Restriction Orifice SizeStarted by Guest_FUNMILAYO_* , 14 Oct 2020 |
