I have read that Hydrolysis (Fat-Splitting) Process for Palm Kernel Oil requires demineralized water.
(De-aearation of water is also desirable)
I've also read that for every particular application a required electrical conductivity of water is used.
Can someone kindly inform me how much electrical conductivity of water is required in the Hydrolysis (Fat-Splitting) Process for Palm Kernel Oil such as the continuous Colgate-Emory process.
I couldn't find this information in literature.
Demineralized Water Spec For Hydrolysis Of Palm Kernel Oil?
Started by process.eng88, Nov 16 2011 12:35 PM
Posted 16 November 2011 - 12:35 PM
Posted 17 November 2011 - 03:37 PM
Dear student 88,
The use of demineralized water in the Colgate-Emory process for fatty oil hydrolysis is basically a metallurgy requirement. The fatty oil hydrolysis reaction to produces fatty acids and glycerin is held at high temperatures and pressures (250 oC and 55 bars). The environment into the hydrolysis reactor is extremely aggressive too. The standard construction for the hydrolysis reactors around the world is based on a carbon steel shell with a stainless steel cladding. Because the high temperature and the use of stainless steel, the presence of mineral impurities (mainly chlorides) must be avoid or the hydrolysis reactor will face severe problems of pitting corrosion. Again, inside of the hydrolysis rector the environment is extremely aggressive and the reactor could corrode very fast. In our process, the basic specification for the demineralized water is:
Conductivity: 0.3 µS/cm (max);
Silica: 0.02 wt ppm (max);
PH: 6.5 - 7.5.
Unfortunately above is the maximum information that I can share with you. I hope may have helped you.
Bests regards,
William Novaes.
PH: 6.5 - 7.5.
Bests regards,
William Novaes.
Waste WaterStarted by Guest_refluxraider_* , 14 Apr 2024 |
Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
Rapid Depressurization Of WaterStarted by Guest_golegolegole_* , 31 Mar 2024 |
Water Seal Pot Of Prv Working PrincipleStarted by Guest_panagiotis_* , 23 Feb 2024 |
Remove Water From Ammonia Aspen PlusStarted by Guest_fmalik_* , 12 Feb 2024 |
