Hi all,
Currently, I have a heat exchanger ( Tower reboiler) whose heating medium is superheated steam at 27 kg/cm2G.
I am studying the possibility of using medium pressure steam ( 14.5 kg/cm2G) for the same exchanger. Can anyone offer any advice on how to proceed ?
thank you
fsk
Change In Steam Grade For Heat Exchanger
Started by PE123, May 29 2012 08:57 AM
Posted 29 May 2012 - 08:57 AM
Posted 29 May 2012 - 09:15 AM
What am I missing? Reducing that much steam pressure will cause quite a reducton in heat load for the reboiler.
Posted 29 May 2012 - 09:27 AM
Hi Srfish,
By design, the heat exchanger area has been overdesigned and the actual duty is also lower than design. As such, it is suspected, the exchanger area ( grossly overdesigned originally) is able to compensate for the reduction in steam pressure.
Kindly note that for both steam pressure grade, the temperature driving force is still available, considering the required process temperature is 160 degC.
How to confirm or check that the exchanger is able to cope with a lower steam grade ?
fsk
fsk
Posted 29 May 2012 - 11:33 AM
Hi fsk,
You need the existing drawings and process information. The existing specification sheet will help. Then use a thermal rating program to see if there is still is excess .surface.
Posted 29 May 2012 - 11:56 PM
Hi fsk,
Measure the chest pressure of the reboiler, cross check this with the condensate temperture leaving reboiler.
Inlet condition of the reboiler =27 kg/cm2g superheated
Exit reboiler condition = saturated condensate at chest pressure.
Rate the reboiler in a simulator (eg HTRI/HTFS) find the operating dirt factor (Vary the Rd to match area ratio=1 ie required area=available area)
Use this Rd and the new conditons at inlet ie MP steam condition.
For reboiler exit condition-
Assume a chest pressure of say 1.0 kg/cm2 less than MP steam condition (to take care of DP in control vavle, FI,piping etc at reboiler inlet. You may need to modify CV,FI, piping to minimize pressure drop in hex inlet)
Reboiler exit condition = saturated condensate at (14.5-1) ~ 13.5 kg/cm2g.
Check the performance of exchanger, if area calculated is less than available area ie Area ratio>1, the hex will perform for new condtions.
Simulating A Single Tube Heat Exchanger In Aspen HysysStarted by Guest_catia_* , 02 May 2024 |
Rate Of Heat Transfer Vs VelocityStarted by Guest_golegolegole_* , 30 Apr 2024 |
Flash Steam Vessel SizingStarted by Guest_JohnFields343_* , 24 Apr 2024 |
Steam AccumulatorStarted by Guest_Valeriacortez11_* , 15 Apr 2024 |
