I need to simulate a pipeline for a distance of 32km running between two different platforms with a riser each at the platforms as well and i am to use Pipesys in Hysys (not pipe segment) for the simulation.
the water depth at platform A is 60m and that at platform B is 6.8m
this was what i did
i simulated the 1st riser as a pipe with a length of 60m and an elevation of 0 i.e cordinates (0.-60) while the origins i assumed to be elevation of 0 and distance of 0 i.e (0,0)
after adding the 1st riser, it solved for the rise and run automatically.
then i added a second pipe copied the data from the 1st since they are both submerged and gave it a length of 32000m and elevation of -6.8m BUT the simulation did not solve,
it displayed an error message saying STEPSIZE FAILURE IN PIPE UNIT 2.
WHAT AM I MEANT TO DO?
i did alot of trouble shooting but still it dint work.
please i would appreciate your answers.
thanks
MAC
Please I Need Help With Pipesys
Started by ehimcqueen, Jun 13 2012 08:07 AM
No replies to this topic
Posted 13 June 2012 - 08:07 AM
Pipesys (In Hysys) Cannot Comprehend Pressure, Temperature & VelocStarted by Guest_IonCube_* , 15 Oct 2017 |
Pipesys Extension On HysysStarted by Guest_DANA-IF_* , 17 May 2014 |
Pipesys Vs Pipesim Vs PipephaseStarted by Guest_Robert Montoya_* , 23 Jun 2013 |
Slug Volume In PipesysStarted by Guest_SAprocessGD_* , 28 Nov 2011 |
Pipeline Simulation Using PipesysStarted by Guest_ehimcqueen_* , 14 Jun 2012 |
