Inter Distance Between Flares
Started by sharjeel39, Sep 18 2012 05:23 AM
8 replies to this topic
Posted 18 September 2012 - 05:23 AM
I am looking for a standard / rule of thumb regarding placement of Amine acid gas flare and Common flare stacks Is this possible to place them close to each other, is their any standard practise that limits this placement.
JHAL JEREH
JHAL JEREH
Posted 18 September 2012 - 05:57 AM
sharjeel,
As per OISD Guidlines interdistance between two flare shall be 90 m.
Posted 18 September 2012 - 08:09 PM
Jhal,
You can also put the two guns in the same stack. This solution is normally applied in refineries.
jrtailor09,
could you kindly provide the meaning of OISD? Thank you.
jrtailor09,
Posted 19 September 2012 - 12:16 AM
OISD means - Oil Industry Safety Directorate.
Ministry of Petroleum & Natural Gas
This standard followd by oil & gas installation in india.
Jatin
Jatin
Posted 20 September 2012 - 04:46 AM
Sharjeel
I think the most important aspect is the impact of Acid gas flare on the Main Flare stack. I think the flares can only be palced closer if these flares are essentially at the same height. The heights will be governed by taking the worst scenario of the two.
The literature does not give clear distance to be set for the subject matter
nooru
nooru
Posted 22 September 2012 - 03:58 AM
TO JATIN,
As per my plot plan i dont how much space like 90m, so this distance is immpossible for me to consider.
Posted 22 September 2012 - 04:17 AM
TO NOORU,
Yes I agree to you that Acid gas flare will have impact on the main flare, I am burning off 1000ppm H2S and 3%CO2 at normal condition and due to the radiation emitted from this flare will always effect the main flare.But if the height of acid gas flare is increased than the main flare, this effect of radiation will be reduced because as height increases the effect of radiation becomes lower.
Thats what my understanding says, but I would like to hear from others in this forum about this.
Posted 22 September 2012 - 11:40 PM
Sharjeel,
Then you don't have any other option.
You have to provide acid gas flare & hydrocarbon flare having same height and adjustant to each other.
Jatin
Jatin
Posted 23 September 2012 - 09:56 AM
Jatin,
Can you please explain me what is the logic behind keeping both flares at same height why can't we place them at different heights.
Kindly consider my explanation of not keeping both flares at same heights and please enlighten me if you feel that my explanation is incorrect.
With authentic literature.
Minimum Distance Between Blowdown Valve And Cold Vent Outlet In A HighStarted by Guest_AMINEBELAL_* , 15 May 2026 |
Flares Tips DesignStarted by Guest_georgesnanga_* , 15 Mar 2023 |
Psv Discharge To Different FlaresStarted by Guest_Shaileshprocess_* , 06 Mar 2023 |
Marking The Mechanical Minimum Distance Between Fittings In P&idStarted by Guest_myself_ritesh_* , 13 May 2020 |
Minimum Distance Between An Attemperatorkum/desuperheater And A SteamStarted by Guest_muthukmaar_* , 27 Apr 2020 |
