Refer to API 2000, Annex A.1.2, it is assumed that the maximum operating temperature of the vapour space of the tank is approximately 48.9°C. If the fluid store at 60°C with Nitrogen blanketing (N2 supply temperature at 45°C), Table A.3 in the Annex A is not applicable in this case and the formula from Section 4.3.2.3 shall be used, is that correct? I found that the thermal inbreathing rate from the formula and interpolation from Table A.3 have a significant different value. Kindly advise. Thanks.
Api 2000 Annex A
Started by CHIM80, Jan 03 2013 04:16 AM
No replies to this topic
Posted 03 January 2013 - 04:16 AM
Determining The F-Factor Following The Api 2000Started by Guest_Hachimi_* , 06 Sep 2024 |
Api 2000Started by Guest_Lucianaa_* , 04 Jan 2024 |
Le, Lemax "api 650 Annex F (Figure 2)"Started by Guest_KevinGTX1_* , 01 Aug 2022 |
Nitrogen, Api 2000 Section 3 Vs Annex FStarted by Guest_Rmm27_* , 23 May 2022 |
Api-2000- Thermal Inbreathing Due To Variation In Rain IntensityStarted by Guest_aju_1807_* , 03 Aug 2021 |
