hello to all,
Generally application of valves in the pipeline is to allow/prevent/regulate the fluid/gas flow.Based on my knowledge the main defect of used valves are passing and jammed.
What is the best practice for maintain the ball/gate/plug valves in the refineries plant ?
Erosion also one of the main problem in refineries plant. Certain organisation applying grease and sealant for maintain the valves with the anti-erosion material.
is it applicable for applying this type of practice in the refineries plant ? Does the purity of the petroleum product will be contaminate ? and which phase of refineries process are having most potential for applying grease and sealant ?
Thank you and looking forward for reply from any expert regarding this.
regards,
Shahir Rosni @ Aeir
