Hi all,
I was wondering how Perry's ChemEng Handbook calculated the enthalpy of moist air at the bulk water temperature in the attached table? I have been trying to duplicate the results but to no avail.
Thank you.
Posted 19 November 2013 - 06:32 PM
Hi all,
Thank you.
Posted 20 November 2013 - 03:48 AM
I think you are confused about hw value. Well let me tell you while calculating cooling tower characteristic, you get two curves on graph. X-axis is temperature and y is enthalpy. First curve is the straight line with L/G slope and that is called air saturation curve. In your case two fixed points of this line have come out to be 41.58 & 60.98 btu/lb at 85 and 105 F temperature respectively. Now come the water saturation curve which will be above the air saturation curve. You have found out corresponding temperarure values so at these temperatures 100% saturation line in psycrometric chart (High temp) will give you enthalpy value.
For better understanding you can refer to below mentioned link.
http://che.sharif.ed...sign Manual.pdf
Hope it helps.
![]() Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
![]() Hello, Design Of Natural Gas Liquefaction Processes.Started by Guest_guoyinyanliner_* , 18 Jun 2025 |
