Hi all,
In ammonia process, absorption of CO2 from process gas is carried out by using potassium carbonate solution as absorbent and DEA as activator.
In breif , I need to know about absorption process involved chemical reaction, and how to design such packed columns. Can any one help me?
Gas Absorption
Started by , Mar 31 2006 02:46 AM
Posted 31 March 2006 - 02:46 AM
Posted 31 March 2006 - 08:31 AM
Dr El-Saadi?,
It is hard to adequately address your question without much more specific information. If you are looking to remove large quantities of CO2 as part of a commercial process, then I suggest you contact a licensor for such technologies. Many years back, I worked with a company (and a process) called Benfield that used hot potassium carbonate/bicarbonate solutions to remove acid gases from a reducing gas stream. I believe an amine activator was involved. That sounds a lot like what you are describing. Equilibrium shifted between the bicarbonate and carbonate forms in different parts of the process and was controlled by a variety of factors. In any case, designing such a process requires experience and in-depth knowledge that are not likely to be easily obtained. Hence my suggestion that you contact a licensor.
Good Luck,
Doug
Good Luck,
Doug
Posted 15 April 2006 - 03:19 AM
You can get the all the information about CO2 absorption and stripping from "gas purification book". Also, I have been working as a process production engineer such a plant. I could may help you.
Sincerely,
blanchy
You can get the all the information about CO2 absorption and stripping from "gas purification book"(You can find it at http://www.amazon.com). Also, I have been working as a process production engineer such a plant. I could may help you.
Sincerely,
blanchy
Sincerely,
blanchy
Sincerely,
blanchy
Electric Heater In Regeneration Absorption BatteryStarted by Guest_alaasleem2026_* , 01 Sep 2024 |
Solvent Carryover Emissions In Absorption ProcessStarted by Guest_TeeEng_* , 24 Oct 2023 |
Which Thermodynamic Model In Aspen To Be Used For Ammonia Absorption IStarted by Guest_Nikhil Shipure_* , 11 Sep 2019 |
Amine Co2 Absorption UnitStarted by Guest_mrh2016_* , 17 Apr 2018 |
Chemical Absorption Of So3 (Sulfuric Acid Making)Started by Guest_Franwis_* , 22 Dec 2021 |
