I might sound a little vague with my question but there is a basic doubt in my mind with this.
While using a cooling water heat exchanger what are the conditions/situations when we put cooling water in shell side and the other process fluid in tube side.
Ayche.
Cooling Water Side In Heat Exchanger
Posted 24 April 2014 - 11:21 AM
Posted 24 April 2014 - 12:23 PM
Generally its something like this
Fluids to be passed through the shell:
High viscosity fluids, fluids with a low heat transfer rate, and those undergoes a phase change
Fluids to be passed through the tube:
Fluids at higher pressure, dirty and corrosive fluids and those which contain solids
I havent seen yet a heat exchanger with cooling water at shell side, unless you can guarantee that this water is very clean.
Posted 24 April 2014 - 12:44 PM
This topic of which side to place cooling water in a heat exchanger has been discussed many, many times and the recommendations and experiences have been submitted in great detail in past threads within our Forums. Do not assume that the shell side is off limits to cooling water. For example, practically all hot, high pressure fluids (such as interstage gas within a compressor ) that need cooling are placed in the tube side - which leaves the shell side for the cooling water.
If you take the time and make the effort, you will find all this information by using our Forum Search Engine.
Posted 24 April 2014 - 12:56 PM
thanks for your valuable inputs art montemayor sir and apologies for starting a new thread
regards
ayche
Simulating A Single Tube Heat Exchanger In Aspen HysysStarted by Guest_catia_* , 02 May 2024 |
Rate Of Heat Transfer Vs VelocityStarted by Guest_golegolegole_* , 30 Apr 2024 |
Chiller Efficiency Dependence On Cooling Water TemperatureStarted by Guest_Neha Vensiyani_* , 29 Apr 2024 |
Waste WaterStarted by Guest_refluxraider_* , 14 Apr 2024 |
