Centrafuge Dewatering Issues Domestic Sludge
centrafuge dewatering sludge
#1 mk1959
mk1959
Posted 19 June 2014 - 07:40 PM
We are operating a centrafuge for dewatering of our sludge here in a West Virginia City.   Approximately 3 months ago we started to have an issue of every 5 to 6 hours of standard operation the centrafuge turning to slop.  We have taken the unit apart and can find NO mechanical issues.
We are at a absolute loss for a solution .
Has anyone ever experienced the same problem ?   Possible solution to this problem ?
This has become a real issue for the operators.
Would appreciate some help !!!
Mark
#2 TS1979
TS1979
  • 164 posts
Posted 19 June 2014 - 09:18 PM
What kind centrifuge do you have? What caused the machine to stop, high torque, high power draw, or high vibration? How about running the machine standby?
#3 mk1959
mk1959
Posted 21 June 2014 - 02:22 PM
17 inch Westfalia centrifuge.
The centrifuge does not go out on high torque, power draw , vibration,     Its not going out.
The problem is after 4 to 5 hours of operation it just goes to slop.    Polymer is fine !     Unit just goes to liquid slop, has to be shut down , ran through the wash down cycle and restarted.   Will then run fine for 4 to 5 hours.
Unit has been opened up and everything looks fine.   Some build up of struvite .
Mark
#4 breizh
  • 6,742 posts
Posted 22 June 2014 - 05:58 AM
Mark,
If nothing wrong with the equipment , you should consider your process and the quality of the material you want to filter . No change over the year ? particle size distribution , viscosity ,.....which may affect the separation ?
You should consult the vendor , it may be able to run test with you material or point you in the right direction
