is there any relation ship b/w pumps rpm and power
or any another relationship.
Relationship B/w Pumps Rpm(frequency) And Power
Started by Guest_Andaleeb_*, Apr 25 2006 03:14 AM
Guest_Andaleeb_*
Posted 25 April 2006 - 03:14 AM
Posted 25 April 2006 - 05:49 AM
Andaleeb:
Of course there is a relationship. Just think about what you mentioned in your query. If a pump increases its RPM (ability to move more fluid per unit of time) it has to increase the amount of work done on the fluid (per unit of time). And if you have been studying and know the definition of "power", then you will find out that it means exactly the amount of work done per unit of time. Therefore, the more the rpm, the more the power required to sustain that same rpm.
The relationship is different for different types of pumps -- this is obvious when you realize that different type of pumps work under different principles and follow different physical laws and yield different efficiencies.
To explain it any further requires that you know as much about pumps, their types, and the mathematical relationships that describe their operation as I do. Otherwise, I would be speaking over your head. Therefore, you have to master all the basic physics and engineering material related to pumps and how they work and perform.
Posted 25 April 2006 - 10:21 AM
And read http://www.gouldspum...f_fullindex.stm (thank you Art for providing this link in another thread).
![]() Centrifugal PumpsStarted by Guest_panoska_* , 01 Feb 2025 |
Understanding Polytropic Head And Its Relationship With Gas DensityStarted by Guest_Kakka_* , 18 Dec 2024 |
![]() Selection Of Type Of Pumps For "negative" Npsha And Solution TStarted by Guest_linda_pro_* , 29 May 2024 |
