Capacity Of Multiple Effect Evaporator
heat transfer multiple effect evaporator
#1 Malti
Malti
  • 7 posts
Posted 18 September 2015 - 06:02 AM
I have a 4-effect falling film evaporator system. I want to increase the capacity of the multiple effect evaporator so as to run it at higher feed flow rate. I want to know what parameters I can change and basically approach this. Is there a maximum capacity of the MEE? Also how can I find out the heat transfer coefficient for falling film evaporator?
  • 6,351 posts
Posted 21 September 2015 - 06:25 AM
Malti ,
Consider reading this thesis .
Good luck,
#3 Malti
Malti
  • 7 posts
Posted 23 September 2015 - 01:54 AM
Thanks a lot. The thesis helped me understand the system better.
#4 Malti
Malti
  • 7 posts
Posted 29 September 2015 - 11:33 AM
Is there a flooding condition for falling film evaporators?
#5 breizh
  • 6,351 posts
Posted 29 September 2015 - 09:16 PM
My understanding :
Thin film means very good distribution of the liquid to prevent flooding and rupture of the film along the pipe  . The thickness of the film is key for heat transfer .
You may find answer to your query in the attached document.
Hope this helps.
Edited by breizh, 29 September 2015 - 09:45 PM.
#6 Malti
Malti
  • 7 posts
Posted 04 October 2015 - 11:20 PM
I also need to know how can I calculate the residence time in this evaporator system. I actually have a pasteuriser in line with evaporator and there is Flow diversion valve that recirculates product if temperature falls below a certain point in pasteuriser. I need to set the control measure for the FDV and I think that will require the residence time.
Thanks.
