Hi ;
I want to know if Hysys v8 can calculate the fouling factor in shelle and tube heat exchanger automatically based on the inlet . thx
Posted 12 November 2015 - 02:11 PM
Hi ;
Posted 12 November 2015 - 05:07 PM
Have you tried?
Posted 20 June 2016 - 11:31 AM
yes u can do it.
Use simple steady state, input 2 inlet stream, give ur HE spec and run hysys.
Then use adjust for 1 of your outlet fluid temperature.
U will get the fouling factor.
Posted 24 July 2016 - 12:44 AM
Steve,
As a Heat Transfer Engineer, it is important to understand the significance of the "fouling factor". In reality, it is nothing but an empirical margin on surface area based on experience with specific process fluids.
I presume, you are trying to back calculate this "margin" on your operating heat exchanger in Hysys by checking the achievable duty vs what the software is calculating. Am I right?
It is important to understand that the number you get from this calculation is an "underperformance" factor and not fouling factor. It "may" be fouling or change in phase at inlet or contaminated streams with different properties or even physical damage to baffles etc.
Cheers
Edited by Dipankarc84, 24 July 2016 - 12:44 AM.
![]() Colebrook's Equation - Friction FactorStarted by Guest_breizh_* , 10 Nov 2024 |
