I think you are looking for a test methodology to know the real performance of your beds. this is called breakthrough test.
to do that you have to have an accurate moisture analyzers in order to take the reading of the water content, by doing so you will have a clear status of your beds performance and you can predict when they needs to be replaced.
the test principle is to to extend the adsorption cycle extra hours more than the normal cycle time until you reach the alarm setting or water content which is different from plant to the other. ( based on my experience it should not be more than 1 ppm).
please let me know if you need further info.
