Restriction Orifice For Liquids
12 replies to this topic
#1 Ankit_Kumar
Ankit_Kumar
  • 72 posts
Posted 23 December 2015 - 05:48 AM
I am in the process of sizing RO for portable water service. Appreciate if someone can tell me that what is the limit for Beta ratio and flow coefficient for RO? Do we need to calculate Noise factor? If yes, how to calculate it?
Below is the calculations. Appreciate if someone can review and provide feedback.
Edited by Ankit_Kumar, 23 December 2015 - 05:53 AM.
#2 Lucian Gomoescu
Lucian Gomoescu
  • 44 posts
Posted 23 December 2015 - 08:59 AM
According my calculations, the results are:
Discharge coeff.: 0.58;
Orifice diameter: 71.81 mm;
d1/d2: 0.354;
Crane Flow Coefficient:160;
cavitation index: 1.6 (< 2, thus cavitation may occur).
BR,
Lucian
#3 Ankit_Kumar
Ankit_Kumar
  • 72 posts
Posted 24 December 2015 - 12:23 AM
@Lucian
Thanx for response. u r right. I checked my calculations and found the error.
Can you tell me how you calculated cavitation index and Crane Flow Coefficient?
Also what is the range of discharge coefficient, d1/d2 and crane flow coefficient ??
#4 S.AHMAD
S.AHMAD
  • 786 posts
Posted 24 December 2015 - 02:38 PM
Hi
My calculation showed orifice diameter of 122.5 mm can let the pressure from 3 to 0.5 kg/cm2.
I attached the excel-file of previous version hoping you can oprn
#5 S.AHMAD
S.AHMAD
  • 786 posts
Posted 24 December 2015 - 03:38 PM
My computation showed an orifice of 71 mm Attached excel file fou you to check I am using C=0.625 at Re>4X104.. This Re is based on orifice diameter.
s.ahmad
#6 S.AHMAD
S.AHMAD
  • 786 posts
Posted 24 December 2015 - 03:53 PM
Normally beta between 0.2 and 0.7 is acceptable for orifice meter. However, if the noise is not acceptable you can install 2 or more RO i series.
Regads
s.amad
#7 Ankit_Kumar
Ankit_Kumar
  • 72 posts
Posted 04 January 2016 - 08:15 AM
Many Thanks S Ahmad.
Can you tell me how cavitation index and Crane Flow Coefficient is calculated? what is the importance?
#8 S.AHMAD
S.AHMAD
  • 786 posts
Posted 05 January 2016 - 02:09 PM
Kumar pls see attached excel fil orificesize . The C value i However I am not fimilisr with csvitstion index but it is good idea for you to calculate the pressure at the orofice using Bernaulli's equation to ensure that the pressure is well above the vapor pressure at conditions.
s.ahmad
#9 Ankit_Kumar
Ankit_Kumar
  • 72 posts
Posted 06 January 2016 - 12:25 AM
Many Thanks. I almost got 4 different spread sheets now to calculate orifice dia or flow whichever is required.
Just one Q. In 2ns sheet, at cell F11, orifice dia was calaulated? Why? As orifice dia is again being calculated at cell D13?
#10 Lucian Gomoescu
Lucian Gomoescu
  • 44 posts
Posted 06 January 2016 - 10:36 AM
Cavitation index is defines as the ratio (P2-Pv)/(P2-P1), where: P2, P1 are the upstream, respectively downstream static pressure (both locations being far enough from orifice in order to have a fully developed velocity field); Pv - liquid vapor pressure @ upstream temperature.
A value of at least 2 gives a safe margin from cavitation conditions. It isn't easy to accurately predict what is the minimum static pressure achieved along the fluid flow path from upstream to downstream, that's why this index value is used to determine if cavitation occurs or not.
The formula for Crane flow coefficient is attached. This coefficient can be used together with the other fittings' K values, e.g. if you want to determine pressure drop on a pipeline containing that restriction orifice.
Lucian
#11 Ankit_Kumar
Ankit_Kumar
  • 72 posts
Posted 05 April 2016 - 12:43 AM
Dear Lucian & Ahmad
I have done calculation for RO sizing based on the following values.
My main concern is regarding Reynold Number which is too much high. Can you guide is this point of concern? If yes, what is the solution?
#12 Ankit_Kumar
Ankit_Kumar
  • 72 posts
Posted 10 April 2016 - 12:08 AM
Kindly reply
#13 breizh
  • 6,775 posts
Posted 10 April 2016 - 12:44 AM
http://www.engineeri...turi-d_590.html
Your calculation is correct , the viscosity and density of your product are low ( based on temperature) , nothing wrong there ..Reynolds number is a consequence .
