Hello everyone,
I'm a bit confused about liquid flowing through a control valve. Suppose for example a centrifugal pump sending a certain flow through a pipeline in which a control valve is present. I perfectly understand how this valve reduces flow as it creates an increased pressure drop (by going from for example from 90% opening to 30% opening) which increases the upstream pressure (suppose downstream pressure constant) on which the pump, according to it's pump curve, provides a lower flow rate.
As I am now studying choked flow in liquid CV applications, I'm a bit confused why the flow rate increases as the pressure drop increases according to this figure:
(http://kb.eng-softwa...99054000&api=v2)
Does this figure just shows how the flow varies through the valve at a certain fixed position? Do I need to interpret this as the flow rate increasing as the pressure drop increases because the valve opening becomes smaller and smaller (for higher pressure drop) and so the velocity becomes bigger and bigger at the vena contracta (Bernoulli) until a maximum is reached (choked flow)? I don't see the link between my two different insights. What am I missing in understanding it properly?
Thanks in advance.
