Let's say we have a reactor operating at 45 bar. There are two feed streams. The first one is a gas stream which is compressed from 1 bar to 45 bar. The second feed stream consists of liquid at 45 bar. It is a combination of fresh feed which is pumped from 1 bar to 45 bar and also a recycle stream from a distillation column which is pumped from 5 bar to 45 bar. Hence the reactor is operated at 45 bar.
1. If the compressor fails, would the mixture in the reactor start to flow into the gas stream and would the gas flow backwards due to the higher pressure?
2. If the pump in the recycle stream fails, would the mixture from the reactor as well as the fresh feed start flowing into the recycle stream as well as the distillation column? The feed stream for the distillation column is actually connected to the reactor with a turbine between them. Would the backflow occur right up to the turbine? (the pressure before the turbine is 45 bar and after is 7 bar before the pump failure). What happens after that?
3. If the pumps in both the fresh feed stream and the recycle stream fail, would the gas feed start flowing into the liquid feed? Also would the liquid in the fresh feed and recycle stream flow backwards due to the higher pressure in the gas stream?
I don't really know the answer to these questions so any help would be appreciated.
Need Some Help With Hazop
Posted 12 March 2017 - 10:26 AM
Posted 12 March 2017 - 08:07 PM
We don't do HAZOPs this way. You should not either.
Posted 12 March 2017 - 09:08 PM
Do you mind elaborating?We don't do HAZOPs this way. You should not either.
Edited by goggles30, 12 March 2017 - 09:09 PM.
Posted 12 March 2017 - 10:25 PM
There are many requirements to be met before conducting a HAZOP. And an important feature is that persons participating in HAZOP are present in the same room at the same time. And the meeting is lead by a certified professional.
Posted 19 September 2017 - 05:06 AM
I've created and small introduction guide to HAZOP Analysis, if you are interested in know more about this subject, please visit:
http://instrumentati...sys-assessment/
Thank you!
Gap From A Hazop - Vacuum In A TankStarted by Guest_ksagarzazu_* , 02 Oct 2022 |
Similar Hazards In A HazopStarted by Guest_HWIK_* , 25 May 2022 |
Hazop Study For Cartridge Filter UnitStarted by Guest_Elmansi_* , 03 Dec 2019 |
Hazid, Hazop, Lopa & Sil Study - Process Engineering DesignStarted by Guest_ponraj_btech@yahoo.coom_* , 27 May 2016 |
Instrumentation Responsibility During HazopStarted by Guest_charlton vijay_* , 01 Oct 2016 |
