Catalysts Used In Hds Process
Posted 14 March 2017 - 02:52 PM
I have been given a task to gather a list of catalysts used in HDS(Hydrodesulfurization) process but I fail to know where to start,Any help regarding this matter would be appreciated(Direct info,Referral to journals,etc)
thanks in advance
Posted 14 March 2017 - 10:48 PM
albemarle, haldor topsoe, axens, criterion, grace, sinopec, clariant...google ;-)
Posted 15 March 2017 - 09:24 AM
Try to obtain a copy of the book "Handbook of Commercial Catalysts" from Howard Rase. In chapter 18.3 you have a good overview.
It is from year 2000, Manufacturers have changed due to mergers and acquisitions. You have however, a good list in the previous post.
The working principles and type of catalysts remain the same. All the improvements in the last 15 years, as far as I know, have been incremental. No breakthrough technology.
Take into account that HDS can be applied to different feedstocks with different additional requirements so there is not a single "hidrodesulfurization" process.
Please explain what is for, so people can give you more detail.
- It is a list of possible suppliers for a bidding?
- It is academic?
- It is a research for a specific problem you are facing?
Posted 15 March 2017 - 03:47 PM
thanks you.
Posted 15 March 2017 - 03:54 PM
Thank you for your time and answer,As for the purpose,as I said before its a little academic project I've been tasked with and its only a data collection.I need a list of catalyst ,Ways of acquiring it ,All data regarding the catalyst(Specific Surface area,etc)and their activity test,Its for academic use and neither commercian nor industrialTry to obtain a copy of the book "Handbook of Commercial Catalysts" from Howard Rase. In chapter 18.3 you have a good overview.
- It is academic?
Process Plant Insights Dot ComStarted by Guest_Pilesar_* , 08 Sep 2026 |
Acetic Acid Plant Using The Cativa Process.Started by Guest_Pilargalizia_* , 02 Jul 2026 |
Density Meter For Inline Process Monitoring In A Distillation ColumnStarted by Guest_ProcessAtWork_* , 18 Jun 2026 |
Ai For Designing Of Process PlantStarted by Guest_Biomass Process_* , 12 Jun 2026 |
Process Engineers / Mechanical Engineers - ResponsibilitiesStarted by Guest_PhilippM_* , 10 Jun 2019 |
