I checked the calculations from your message #26, found no calculation errors, and have only a few remarks.
First of all it is important to note (and always include in your calculation report) on what reference state pressure Po the data from your sources are based. See note 2 at the bottom of Table C.4 of your textbook. The K that you calculate for the reforming reaction is then valid for that Po. For the WGS reaction it does not matter whether Po is 1 bar or 1 atm because the number of moles does not change, but for the reforming reaction it does..
Secondly it is important to realize that due to the exponential character of K the slightest inaccuracy (or error) in input data will have a noticeable effect on the calculated K. For example:
You use 298 K as the reference temperature, resulting in Kref = 386.5 and Kwgs = 0.925 , however when using the correct 298.15 K you would have found Kref = 380.9 and Kwgs = 0.927
In your older calculation in message #22 you rounded the calculated ΔHfo to 206000 which then had an impact of 4 % on the calculated K.
Edited by PingPong, 05 January 2018 - 06:00 AM.
