Api 2000 - Annex F
7 replies to this topic
#1 Raj Mehta
Raj Mehta
  • 150 posts
Posted 13 August 2018 - 03:23 AM
The API 2000 Annex F gives different levels for tank blanketing, however, what is not clear to me after reading the document is, how can I be sure whether level 1 (minimum inert-gas blanketing) provides sufficient blanketing or whether I have to go for level 2 or 3 to ensure safety at all levels (personal, environmental, product)?
The very first line of Annex F mentions "All three levels provide comparable flashback protection". Does this imply, that either of the levels can be used? If yes, then is it necessary to have a flame-arrester, as I understand from this topic (post # 5) by Montemayor, to avoid FA's whenever necessary.
Thank you!
Best regards,
Raj Mehta
#2 Raj Mehta
Raj Mehta
  • 150 posts
Posted 14 August 2018 - 11:45 PM
Could anyone please clarify this for me?
#3 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 15 August 2018 - 08:44 AM
I would recommend you to read the article related to application of flame arresters in the link below. German standard TRbF 20 has explicit guidelines for installing flame arrester application. Refer the links below:
https://www.aiche.or.../20131216_1.pdf
http://www.hemmingfi..._arresters.html
Ankur
#4 Raj Mehta
Raj Mehta
  • 150 posts
Posted 16 August 2018 - 12:08 AM
Thanks Ankur for sharing the articles.
Could you also perhaps shed some light on the other two questions in my post # 1 (highlighted below for quick reference)?
1. The API 2000 Annex F gives different levels for tank blanketing, however, what is not clear to me after reading the document is, how can I be sure whether level 1 (minimum inert-gas blanketing) provides sufficient blanketing or whether I have to go for level 2 or 3 to ensure safety at all levels (personal, environmental, product)?
2. The very first line of Annex F mentions "All three levels provide comparable flashback protection". Does this imply, that either of the levels can be used?
Edited by Raj Mehta, 16 August 2018 - 12:09 AM.
#5 Raj Mehta
Raj Mehta
  • 150 posts
Posted 17 September 2018 - 10:32 AM
Reminder, to kindly help me with the queries in my previous post.
Thanks!
#6 fallah
  • 5,025 posts
Posted 19 September 2018 - 09:33 AM
Thanks!
Hi Raj Mehta,
Please upload the page of App. F including three levels blanketing you described, as at the moment i haven't in hand the last rev. of API 2000...
#7 fallah
  • 5,025 posts
Posted 22 September 2018 - 03:34 PM
Hi Raj Mehta,
1- It's up to you using each level for blanketing; but using level 1 will force you applying especial FA while using level 1 will exempt you applying any FA for flashback protection.
2- Yes, either of level can be used.
#8 Raj Mehta
Raj Mehta
  • 150 posts
Posted 24 September 2018 - 02:12 AM
Thank you Fallah for the clarification.
