dear all,
I m Dinesh working as a design consultant, mumbai.
As we r going to design an evaporator system with backfeed arrangement while using 4 evaporators in series for the production of 1 ton calcium chloride (80% Moisture content) and the feed is 7143 kgs per hr of 14% calcium chloride. The first evaporator (from where the product is coming) is working at negative pressure (650mmhg) and from the last evaporator feed is charged at given rate and is heated while using 20 bar steam with 3000 kg/hr rate and operation is carried out by force circulation method.
Help me to design an evaporator and also explain the presure temperature detail in all evaporators.
Waiting for ur earliest reply.
thanks & regards,
Dinesh
Query On Evaporator.
Started by dinesh, Sep 14 2006 02:54 AM
No replies to this topic
Posted 14 September 2006 - 02:54 AM
Multiple Effect Evaporator Calculation With Multiple ComponentsStarted by Guest_addiesalsabil_* , 13 Jan 2024 |
Troubleshooting Of Wfe - ( Wiped Film Evaporator)Started by Guest_DivineFist001_* , 29 Nov 2023 |
Realistic Approach Temperature For Evaporator Heat ExchangerStarted by Guest_reason991_* , 29 Jul 2023 |
Query Regarding The Mole Flows Of A CstrStarted by Guest_Marcaus01_* , 23 Jun 2023 |
Falling Film EvaporatorStarted by Guest_Alare_* , 15 Mar 2023 |
