Temperature Cross Heat Exchanger
heat exchanger temperature cross
#1 Priolo
Priolo
  • 7 posts
Posted 12 August 2019 - 12:47 PM
I would like to ask if a temperature cross (Hot outlet - Cold Outlet < 0 ) is possible to reach in a TEMA Type Heat Exchangers with 2 tube passes.
Let's imagine to have  a BEU TEMA Type exchanger (2 tube passes, 1 shell pass) where in both shell and tubes we have hydrocarbons.
If for the design case (highest duty and highest flowrate) we have considered a temperature approach Hot Outlet - Cold Outlet = 0, at reduced duty and flowrate (both on tube and shell side) it's possible to have temperature cross (Hot outlet - Cold Outlet < 0 )?
I've simulated with PRO/II the two scenarios (design and reduced flowrate) and, keeping for both the UA calculated in the design case, I got a temperature cross for the reduced flowrate case. Is this possible? Lot of forums say that temperature cross is not possible in multipass heat exchangers.
Thank you.
#2 AlertO
AlertO
  • 194 posts
Posted 25 August 2019 - 10:10 PM
Hi alek
In case you have done simulation with the software, you should realize that it is just math where it may consider the backward heat transfer from cold side to hot side into the calculation and give you a result. If proper, it should state with a warning. All of this depends on many factors (software capability, your input correctness) and finally, you need to analyze your system properly.
Anyway, with 2 tube passes, you can apply Shell 'F' from TEMA to have an ideal counter flow. This will minimize the reverse heat transfer at any individual portion through the exchanger.
In addition, one tube pass may be another alternative and simple one.
Hope this may help you.
Edited by AlertO, 25 August 2019 - 10:28 PM.
#3 ankitmalhotra
ankitmalhotra
Posted 07 September 2019 - 10:36 AM
A temperature cross is possible in a counter-current or a multi-pass heat exchanger as it has a counter current section. It is not possible in a co-current heat exchanger.
Lets take an example of a heat exchanger. Ideally one would prefer to have a counter current one pass design as it gives the maximum MTD. But because of multiple constraints it is often necessary to have a multipass design. Let us consider a 2 pass design.
One option here would be to have the first pass as counter-current and second co-current. In this scenario a temperature cross will mean that in the second pass, there would be reverse heat transfer for the fluid to end up hotter than the hot fluid outlet. The reverse heat transfer is compensated by the high MTD in the first pass, when we compare this to the reverse - co and counter arrangement.
The second option would be to have the reverse, first pass as co current and second as counter current. Here, there will not be a reverse heat transfer, but one would end up with the same MTD as approach 1 as the MTD is lower than the first approach (counter- co ) in Pass one and better than it in Pass-two.
Making a graph of Temperature vs length and plotting both shell side and tube side temperature for the two approaches would help in the understanding.
You can validate this using any heat transfer software such as HTRI Xist, which allows you to quickly change the configuration and make relevant plots.
What it a temperature cross does signify is that MTD takes a sharp dip as the temperature cross increases and hence the area requirement increases for a design case.
This is where having exchangers in series helps. Theoretically, having infinite number of exchangers where the overall fluid flow is countercurrent but inside each is a co-counter mixed is as good as an overall countercurrent design, thus even having 2 shells in series is better than one shell in terms of MTD.
#4 Yogan
Yogan
  • 4 posts
Posted 26 February 2024 - 08:44 AM
Hello guys,
I am facing a similar situation. I posted my troubles here:https://www.cheresou...-exchanger-lng/
If some of you with more experience could help me, I will be glad.
Thank you for your attention.
