Dears,
I am in a project in which I am developing three models (maybe more): Process model in Aspen HYSYS, heat transfer model in HTRI, and hydraulics in an in-house software.
The project has an existing vaporizer that will have a level control valve at its inlet piping. We knew the flow, inlet temperature, and the desired outlook temperature of the tube side fluid from the beginning. The exchanger geometric parameters were anticipated to take time to be available. So, we developed the HYSYS model. After the exchanger's geometry has been available, we developed a rating model in HTRI. The overdesign factor result has been too big (around 200%).
Now,I am in a position to do the hydraulics and establish the process data for the control valve.
My question is that is the flow rate value which we got from
HYSYS and used in HTRI realistic to be used in the hydraulics of the shell side fluid?
I feel there is a missing step and it might a simulation case in HTRI (not rating).
Appreciate your feedback.
Integrating Process, Heat Transfer, And Hydraulics Models
Started by Vegeta, Oct 23 2019 01:38 PM
No replies to this topic
Posted 23 October 2019 - 01:38 PM
How To Estimate The Water Dewpoint From Heat And Mass Balance Of NaturStarted by Guest_krishnnaa26_* , 30 Apr 2026 |
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
Process Engineers / Mechanical Engineers - ResponsibilitiesStarted by Guest_PhilippM_* , 10 Jun 2019 |
Waste Heat BoilerStarted by Guest_Prim_* , 25 Apr 2026 |
