Hi...
What is telemetry....and what is telemetry system ?
Telemetry System
Started by hardiskuae, Nov 21 2006 07:43 AM
Posted 21 November 2006 - 07:43 AM
Posted 21 November 2006 - 12:09 PM
Harddisk:
Why are you so LAZY? You are giving ChE students a bad name.
All I did was key in telemetry into the Google database and the first hit was the answer:
http://en.wikipedia.org/wiki/SCADA
Even though you are lazy, you bring up an important subject in process control and operations. Telemetry is the practice of sending signals over long distance for the sake of remotely monitoring or controlling a process - such as is the case of remote located gas/oil wellheads that need to be controlled by a central Operations Center. One or a few operators can manage/control a multiplicity of gas/oil wells with telemetry.
The term SCADA (Supervisory Control And Data Acquisition) usually refers to a central system that monitors and controls a complete site or a system spread out over a long distance (kilometres/miles).
Telemetry is the transmission of those signals between the source and the Control Center. This is an important subject that should be studied by ChE - especially those entering production/operations. The expertise on how/when to transmit and receive useful process signals will be of vital use in the future for many ChEs.
Posted 21 November 2006 - 09:10 PM
Thank you for the answer Art Montemayor
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , 26 Apr 2024 |
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
Closed Drain SystemStarted by Guest_Falah_* , 26 Mar 2024 |
Lube Oil System For TurbomachineryStarted by Guest_bckesim_* , 03 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
