Pvsv
production tank
#1 Ali4269278331
Ali4269278331
  • 31 posts
Posted 24 February 2024 - 12:23 PM
Hi dear guys
we have a low pressure tank that used for crude oil storage. this tank equip with PVSV that control the inside pressure. which is standard allow to us that install a isolating valve before/after the PVSV? Now, we are going to isolate the tank and then doing overhual maintenance.
thanks
#2 fallah
  • 5,026 posts
Posted 24 February 2024 - 01:31 PM
Hi dear guys
thanks
You can consider such isolation valve before/after PVSV, same as what applied in PSVs, provided that it would be full bore and also installed in LO (Locked Open) position.
#3 Ali4269278331
Ali4269278331
  • 31 posts
Posted 25 February 2024 - 12:35 PM
thanks dear Fallah, today i find a text in the API2000 standard that explation your idea. i attached. this is correct or not?
thanks
  • Attached File  ALI.jpg   176.11KB   0 downloads
Edited by Ali4269278331, 25 February 2024 - 01:06 PM.
#4 fallah
  • 5,026 posts
Posted 25 February 2024 - 02:22 PM
Hi Dear,
It's absolutely right...
