I need information regarding to 3 and 4 way valves including their application,shape,and etc.
Thanks in advance,
Best Regards.
3 And 4 Way Valves
Started by jprocess, Dec 23 2006 06:08 AM
Posted 23 December 2006 - 06:08 AM
Posted 23 December 2006 - 09:47 AM
"Control Valve Handbook": http://www.documenta.../book/cvh99.pdf
Three-way valves are often employed for hot fluid flow control through process reboilers. One Google search will come up with all information you need.
For example:
DIRECT-ACTING 3-WAY VALVES
Three-way valves have three port connections and two valve seats. One valve seal always remains open and the other closed in the de-energized mode. When the coil is energized, the mode reverses. Various valve operations can be obtained according to how the fluid medium is connected to the working ports. The fluid pressure builds up under the valve seat. With the coil de-energized, a conical spring holds the lower core seal tightly against the valve seat and shuts off the fluid flow.
Unlike the versions with plunger-type cores, pivoted-armature valves have all port connections in the valve body. An isolating diaphragm ensures that the fluid medium does not come into contact with the coil chamber. Pivoted-armature valves can be used to obtain any 3-way valve operation. Pivoted-armature valves are provided with manual override as a standard feature.
For example:
Posted 23 December 2006 - 04:52 PM
jprocess:
You have to give specific, and relevant information about what you need if you expect accurate and useful responses. Are you talking about:
- the color of 3 and 4 way valves?
- The weight of 3 and 4 way valves?
- The shape of 3 and 4 way valves?
- The price of 3 and 4 way valves?
There are 2 basic divisions of valves:
- Block and throttling manual line valves; and
- Automatic control valves that operate through an actuator receiving an instrumented signal.
- Plug;
- Ball.
Please give us the necessary details and precise information on what you mean and what is your purpose for employing these valves. We can give you a world of experience and expertise on these type of valves - and for FREE. But you have to contribute at least the same amount of effort as we do in answering your request. If you turn in a half-hearted, badly and sadly-worded query, what do you expect to receive?
We await your reply so we can help out.
Posted 25 December 2006 - 07:52 AM
Dear all,
Thanks a lot for your answers.
You are completely right.I will try to make my questions with more details in the future.
But as you see i limited my question about these valves to their application and shape.
Warm Regards.
Warm Regards.
Posted 27 December 2006 - 06:53 AM
In practise where I work 3 and 4 way valves are used for specific purposes;
> 3 way valves for switching between twin additive tanks (one is used while the other is filled and homogenized; the system uses two coupled 3 way valves - additive to system on one, water to additive tank on the other)
> 3 way valves for switching between a feedline and a purge line
Both are similar T shaped valves (VERY different sizes, mind you), ball valves with a 90' angled hole in them. So turning the handle 90' switches from one source to the other (with sources at the left and right side of the T and the output at the bottom).
> 4 way valve for inverting flow direction (of cooling water) through a condensor (which makes built in brushes run through the pipes to clean them)
The valve is HUGE and basically consists of one plate with two holes at one side (one for cooling water feed, the other for runoff), a plate with a hole facing it and a swingtube. The swingtube moves from one hole to the other (using an electric motor, timer controlled).
Posted 02 January 2007 - 07:57 PM
Oh! Nearly forgot this TINY three way valve on the Tiptronic burette; its about the size of a 50 Euro cent coin in diameter. In one position its used to fill the burette, in the other position to dispense from the burette.
Air Consumption For On Off ValvesStarted by Guest_itsmetinnie_* , 11 Mar 2024 |
Fail Open And Fail Close Of Instrument Control ValvesStarted by Guest_panagiotis_* , 04 Feb 2024 |
Two Parallel Jt Valves For GasStarted by Guest_Mohamed_Mamdouh_* , 19 Jun 2023 |
Isolation Valves At Psv InletStarted by Guest_Moh.Abdelhameed_* , 16 Aug 2022 |
