Boiler Chemical Dosing Pump Sizing
  • guestGuests
  • 0 posts
Posted 20 March 2007 - 03:53 AM
I am a process engineer for a power plant, I have been in this company for three years now. I am required to design a boiler chemical dosing pump, we dose ammonium hydroxide, sodium hydroxide and trisodium phosphate. The boiler drum operates at 150bar. What is the dsign criteria for this pump.
Eskom
#2 Rahimzadeh
Rahimzadeh
  • 282 posts
Posted 20 March 2011 - 02:16 PM
Dear :
for sizing your chemical injection sizing at first you must clear the following items:
1-type boiler feed wate(water analysis)
2-boiler power?
3-level of all chemical in boiler
i must add injection caustic is very danger for boiler cause serious damage.
Best regards
#3 breizh
  • 6,786 posts
Posted 23 March 2011 - 03:14 AM
Hi Edwell ,
Let you consult the company in charge of the water treatment in your facility ,if any or contact vendor of dosing pump like milton roy or dosapro .
Hope this helps
#4 ahmedsoorma
ahmedsoorma
  • 4 posts
Posted 22 April 2011 - 02:40 PM
Milton Roy dosing pumps are very good. The Vendor will provide you with the appropriate dosing pump.
Caustic soda increases the pH. The boiler should operate at pH 9.5-10.0 and not greater. Caustic Embrittlement can occur if pH is not properly maintained. You should have a continuous pH monitoring 24/7.
Dissolved Oxygen is another factor to consider. You should be looking at catalyzed Sodium Sulphite if boiler is rated below 200 psia. 10 ppm of this for every ppm of dissolved Oxygen.
Foaming and carryover are also to be observed. If boiler steam is used live, you must ensure this does not take place.
A good water treatment company should monitor all the parameters and train your operators to carry out the proper treatment.
