Is there a rule of thumb used in determining the flow required through the recycle line on the pump discharge in case of minimum flow problem in pump? If yes, what percentage of the pump flow is considered to flow through the recycle line.
Responce is highly welcome.
Flow Through Recycle Line
Started by asade abiodun, Aug 02 2007 07:00 AM
Posted 02 August 2007 - 07:00 AM
Posted 02 August 2007 - 01:54 PM
Seems like the answer would be:
Minimum recycle flow = Minimum flow required by pump - Feed flow to pump
Am I understanding the question correctly? You're using the recycle to maintain a minimum flow at the pump suction...correct?
Posted 03 August 2007 - 01:37 AM
Admin,
you answer my question rightly. May i ask how can i determine the minimum flow required by the pump since i have the feed flow to pump.
Thanks for your responce.
Posted 03 August 2007 - 05:26 AM
I've seen estimates anywhere from 10% up to 50% of the normal flow depending on the size of the pump. Your best bet would be to contact a manufacturer of the pump you have or are considering and they will be able to give you a better answer. If you are sizing the pump then go to the manufacturer website. Many (Goulds, Durco/flowserv) have sizing software on-line. The sizing program will give you an estimated minimum flow required.
Posted 03 August 2007 - 06:18 AM
In determination of min. flow we must assume that the horsepower at blocked-in conditions turns into heat.
The minimum flow is determined such that carry away this heat at a 15 Deg.of Far.(as a normal value) in its temperature, and you can calculate that by a simple material and energy balance.
Anyway, if you need ,I can present an example for you in this regard.
Posted 03 August 2007 - 06:34 AM
60.
Posted 03 August 2007 - 10:18 AM
Fallah has pointed one factor affecting pump minimum flow. There are other factors determining pump minimum flowrate.
3 other points that i can remember.
i) Fluid temperature rise
ii) Minimum system stable flow
iii) Internal recirculation
iv) Thrust capacity
Phil has cleared pointed that 10%-50%. Personally i use 30%-40% for first guess (during basic/conceptual design phase). Somehow this needs to be confirmed during Detailed Design with pump vendor input.
JoeWong
iv) Thrust capacity
JoeWong
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
Barometric Legs Line SizingStarted by Guest_panagiotis_* , 17 Mar 2023 |
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
