Hi
I HAVE COME ACROSS A SITUATION WHEREBY I HAVE A NEGATIVE BACKPRESSURE(VACUUM) IN THE DISCHARTGE LINE OF A PSV.
Is this going to affect the performance /opening of the PSV........any other issues i need to take care?
Vinod
Vacuum In The Tail Pipe
Started by vinod, Jan 03 2008 03:08 AM
Posted 03 January 2008 - 03:08 AM
Posted 03 January 2008 - 04:23 AM
QUOTE (vinod @ Jan 3 2008, 03:08 AM) <{POST_SNAPBACK}>
Hi
Vinod
Vinod
Normally no as your downstream pressure is under critical flow for gas.
Posted 03 January 2008 - 06:37 AM
It all depends on the type of PSV; balanced bellows (no), conventional (posssibly; effective set pressure may be lower than expected).
Other issues: None really. Joe addressed flow.
Vacuum Pump Power EquationStarted by Guest_hysyshunter_* , 22 Apr 2024 |
Answered
Vacuum Ejector Pressure ControlStarted by Guest_himanshu.ch_* , 19 Mar 2024 |
Vacuum DistillationStarted by Guest_hysyshunter_* , 12 Mar 2024 |
Issue With VacuumStarted by Guest_Aksu007_* , 29 Feb 2024 |
Higher Pipe Line Dia Specification In UnisimStarted by Guest_Praveen Perumandla_* , 27 Feb 2024 |
