75 L of liquid ethanol at 70 degrees and 55 L of liquid water at 20 degrees are to be mixed in a well-insulated flask. The energy balance for this constant pressure process is Q=delta H.
a.) neglecting evaporation and the heat of mixing, estimate the final mixture temperature.
Please Help Me With This Problem~
Started by , Apr 11 2008 10:29 AM
Posted 11 April 2008 - 10:29 AM
Posted 18 April 2008 - 04:44 AM
Simple balance (if evaporation and mixing heat are neglected):
V(H2O)*ro(H20)*cp(H2O)*(Tk-T(H2O)) = V(Ethanol)*ro(Ethanol)*cp(Ethanol)*(T(Ethanol)-Tk)
where Tk is the final mixture temperature...
ro - densities [kg/m3]
cp - specific heat [J/kg*K]
V - volume [m3]
T- temperature [K} or [deg.C]
sorry for SI units ;-)
V - volume [m3]
Problem With Writing Offshore Plant Design BasisStarted by Guest_Doneisbetterthenperfect_* , 01 Dec 2023 |
Problem With Writing Offshore Plant Design PfdStarted by Guest_Doneisbetterthenperfect_* , 06 Dec 2023 |
Crude Oil Stripping (H2S Conc. Specified In Gas Phase Problem)Started by Guest_nabeelsp1036_* , 16 Jun 2023 |
Aspen Hysys Rankine Cycle ProblemStarted by Guest_ELLEPI_* , 17 Apr 2023 |
Low Velocity Problem Of Fluid In Hairpin Heat ExchangersStarted by Guest_AnbIran_* , 16 Jan 2023 |
