I have query regarding upstream and downstream piping for control valve and orifice flow meter in my project.
As per Orifice Flow meter and Control valve supplier, upstream and down stream minimum straight distance is required for better operation and performance.
Minimum Distance suggested for steam or vapour fluid:
- Orifice flow meter: Upstream Distance is 10 times Diameter of pipe and Downstream Distance is 5 times Diameter of pipe. ( i.e.10 D by 5 D )
- Butterfly type control valve: Upstream Distance is 6 times Diameter of Valve and Downstream Distance is 4 times Diameter of Valve . ( i.e. 6 D by 4 D )
I have do not have straight distance available due to layout constraint.
Under such condition, What will be impact on performance if distance is reduced?
Is there any information or literature on this subject?
Thanks in anticipation.
Sunil
Minimum Distance For Flowmeter And Control Valve
Started by Guest_sunilchaudhari_*, Oct 27 2008 08:23 PM
Posted 27 October 2008 - 08:23 PM
Posted 28 October 2008 - 01:46 AM
It affect the measurement accuracy.
Search with Google...plenty of literature available.
Posted 28 October 2008 - 12:08 PM
Sunil,
The straight lengths upstream / downstream of the orifice depend on what is known as (beta) B value. (B is the ratio of the diameter of the orifice to the internal diameter of the pipe). The value you have quoted is for a very low B of less than 0.3, and that too is the bare minimum. For higher values of B, these values are even higher.
All that will happen if you reduce the straight distances is that the accuracy of measurement will be affected. There are many published data you can get by using a search engine; better still there are many books & manufacturers’ catalogues that can throw more light on the area of your interest.
An instrumentation engineer would refuse to accept these values as it, as they are very finicky about the accuracy of the measuring instrument! However if you can sacrifice the accuracy say to ± 8% or more you can reduce the straight lengths even to 5D by 2D (using your nomenclature)!
You should realise that the straight lengths especially on the upstream side of the orifice is to stabilise the flow and eliminate swirls etc. especially after fittings such as elbows, (or double elbows in some cases). If your layout does not permit such luxuries, you may fit flow straighteners or flow conditioning devices, immediately after the previous upstream fitting, as a remedial measure. However I have always seen that it is possible to improve the layout with some out of the box thinking at least to some extent, before sacrificing the accuracy.
The same reasoning applies for control valves.
Posted 03 November 2008 - 06:17 PM
I agree with Rama and Joe. My experience is that the distance is very important for the accuracy of the reading, to get reliable results, it is recommended that it is followed.
There was a flow rate i had to measure - there wasn't a flowmeter on the pipeline, nor did i have access to a portable one at the time. The minimum distance was just under 3 pipe diameters. I had to hire an instrumentation contractor to measure the flow and he, outright, refused to take any readings at that point.
The result was that i had to get scaffolding constructed at another location where the distance was sufficient. Later, when i measured the flow at both places, using a portable ultrasonic flowmeter, the values were approximately 30 m3/hr apart and it turned out that the value measured by the vendor was right.
I have also used straightening vanes just downstream bends and valves, but they, too, require placement according API codes. In the Plant i work on, one particular straightening vane was not installed according to the API code during the design in 1996 and to this day, the flow is always inaccurate.
Hope this gives a guide,
SM
SM
Posted 04 November 2008 - 02:39 AM
"Coriolis" type flowmeters are not vulnerable to this as they directly measure mass flow - however they are usually much bigger and this can make a problem to fit an instument if you have limited space (my flowmeter for max flow around 10m3/h has 545mm flanfe-to-flange distance and its weight is 18kg!)
![]() Real Or Ideal Cp/cv For Control Valve CalculationsStarted by Guest_sumwunrandom_* , 14 Oct 2025 |
![]() Sizing And And Process Control Of Filter PressStarted by Guest_Amalina Jamil_* , 11 Mar 2019 |
Igv Control For CompressorStarted by Guest_Lyne_* , 30 Aug 2025 |
Automatic Choke ValveStarted by Guest_Mudassssir011_* , 22 Jul 2025 |
