hello,
i would like to know if glycol loses (TEG) increase with pressure in absorption dehydration towers ?
regards
Glycol Loses
Started by Miguel, Dec 07 2008 11:34 PM
Posted 07 December 2008 - 11:34 PM
Posted 08 December 2008 - 03:56 AM
For a properly designed and operated system, the answer is: NO
Foaming induced by high pressure operation is something related to distillation towers, where liquid and vapor phases are in equilibrium across the tower. In such cases, foaming is followed by losses of liquid in the overhead vapor stream.
If inlet separator is designed to handle feed gas the way it should, and if lean glycol temperature is 5-10F above the feed gas temperature, glycol losses in absorber tower will be minor (as usual).
Posted 08 December 2008 - 06:56 PM
thank you zauderberg.
i would like to know what is a standard aceptable, % of glycol loss in a dehydration system
Posted 08 December 2008 - 07:49 PM
From separation perspective, high pressure would lead to higher carry over.
In TEG column, foaming has more concern than ordinary gas carry over.
Increase pressure in TEG also results higher operating pressure in upstream separator. Higher pressure in upstream separator lead to more HC carry over into TEG column and subsequently lead to more potential of foaming in TEG column. Foaming in TEG will cause higher carry over.
Above is just a analysis. However, it your system operating envelop has captured high pressure operating mode, then don't see issue.
Posted 09 December 2008 - 09:17 AM
thank you Mr. Wong
ive simulated my process, subject ive treated here some posts before this one, and i have a total glycol loss of 0.326 gal/MMSCF , ive investigated online, and ive read that 0.1gal/MMSCF is a normal standard for glycol loss i would like confirmation on that, and i would like to know if my losses are aceptable
thank you very much for your responses.
regards
regards
Posted 09 December 2008 - 10:30 AM
http://www.cheresour...?showtopic=5040
Process simulators are quite unreliable for predicting TEG operation parameters (and glycol losses as well).
If your number comes from the simulator, I wouldn't pay much attention about it.
Triethylene Glycol (Teg) Regeneration SystemStarted by Guest_guoyinyanliner_* , 23 Jul 2025 |
Propylene Glycol Cooling Water For Closed Loop SystemsStarted by Guest_J_Leo_* , 10 Jan 2023 |
Meg &teg (Glycol)Started by Guest_Boost_* , 29 Jun 2021 |
Design Of Distillation Column For Separation Of Propylene Glycol FromStarted by Guest_sharonlae_* , 16 Mar 2019 |
Glycol Regeneration. Property Package In HysysStarted by Guest_qwiie_* , 14 Sep 2018 |
