Hi Every One:
How do a process engineer find the insulation thickness. for example
if there is Therminol 59 flowing in a 10" pipe @355 F. The thickness of insulation for that pipe is 2.5". How do we calculate this thickness.
Thank you very much for your help in advance.
Insulation
Started by process705, Mar 02 2009 12:13 PM
Posted 02 March 2009 - 12:13 PM
Posted 02 March 2009 - 12:48 PM
Check out the following links to understand how to calculate the economic insulation thickness.
http://www.cheresour...ulationzz.shtml
http://www.therminol.../tools/pipe.asp
The first one is a wonderful article about insulation on our beloved Cheresources and the second link will lead you to a software for insualtion thickness calculation.
Posted 06 August 2009 - 07:26 AM
Hi Ankur,
Thanks a lot......
Benoy
Thanks a lot......
Benoy
Hot InsulationStarted by Guest_Lyne_* , 14 Apr 2024 |
Insulation Of Fired Heater StacksStarted by Guest_Sherif Morsi_* , 05 May 2020 |
Insulation Of Fired Heater StacksStarted by Guest_Sherif Morsi_* , 26 Apr 2019 |
Personnel Protection Insulation For Cryo ServiceStarted by Guest_Sara Owens_* , 06 Dec 2018 |
Heat Losses Through Cold InsulationStarted by Guest_Movers_* , 02 Oct 2018 |
