How to define distillation column without condenser in aspen plus? In this scheme, the top stream from the column is compressed so that it can be condensed at higher temperature, enabling the condenser and reboiler to be integrated together as single heat exchanger.
[attachment=1567:fixed.jpg]
Propylene-propane Distillation Process With Heat Pump
Started by oedipus, May 24 2009 04:34 AM
Posted 24 May 2009 - 04:34 AM
Posted 24 May 2009 - 09:14 AM
If someone can write a small tutorial step by step, how to run a simulation, the data are complete. Pressure at outlet of compressor is 18.34 bar. Compression ratio =2.
Posted 04 June 2009 - 08:16 PM
QUOTE (oedipus @ May 24 2009, 08:14 AM) <{POST_SNAPBACK}>
I have the same question as you...except my column is C2 splitter.
If you get an answer...please reply in my thread.
thanks
Posted 08 June 2009 - 06:22 PM
i asked this question to AspenPlus tech support.
He said use "RadFrac" model with no reboiler and no condenser .Im doing the same.
thanks.
thanks.
Posted 09 June 2009 - 09:15 AM
In this forum I got the answer (http://www.eng-tips....d=245839&page=1), still have the problem that with a different data ran simulation to converge without errors, I decided to HEATX, because with the heat stream I do not know to link two Heater. If you heard something notify me.[attachment=1599:a.bmp]
Simulating A Single Tube Heat Exchanger In Aspen HysysStarted by Guest_catia_* , 02 May 2024 |
Calculate Mabp,wabp,cabp And Meabp From Distillation Astm D86 ResultsStarted by Guest_barks123_* , 30 Apr 2024 |
Rate Of Heat Transfer Vs VelocityStarted by Guest_golegolegole_* , 30 Apr 2024 |
Turbine Driven PumpStarted by Guest_Rahimzadeh_* , 27 Apr 2024 |
Vacuum Pump Power EquationStarted by Guest_hysyshunter_* , 22 Apr 2024 |
