Conversion Of Nm3/hr Of Air To Nm3/hr Of Blanketing Gas
Posted 28 September 2009 - 07:31 AM
Just want to know what is best practice in reporting the blanketing gas demand fig.among the following:
1) Calculate Nm3/hr of Air per API 2000 based on the liquid movement in the tank and reporting the same (i.e Nm3/hr of Air ) without correcting it for type of blanketing gas used. (i.e.demand fig. will be same irrespective of type of blanketing gas used)
2) Calculate Nm3/hr of air per API 2000 based on liquid movement in the tank and then reporting the value after correcting for type of blanketing gas used.(as used by Enardo;in line with Enardo euqation concept)
As most of you have definitely worked earlier on blanketing gas in tank farm,hence hope to get satisfactory reply for commonly used practice regarding reporting (whether (1) or (2)) of the above.
Posted 28 September 2009 - 11:50 PM
I think we should use the point (2). although the volume replacing the liquid movement out is the same, but the consumption of the blanketing gas from source may different with the different molecular weigth and temperature/pressure.
Posted 06 October 2009 - 09:18 PM
The reported Nm3/hr (Metric) in the standard is not actually a measure of volume, but of moles.Hi,
I think that mole wise, you can use the values presented in API. It's up to the engineer to convert it with considerataion of the blanketing source operating conditions/properties.
I've used this philosophy to establish my N2 requirements in my project that I'm handling at the moment. In my case, this is warranted since N2 and air have almost similar MW.
But if your blanketing agent differs in MW w/ respect to air, then I guess you have to compensate for the specific volume of the blanketing agent. But IMHO it won't differ much since we're talking about conditions that we can assume ideal gas behavior.
My 2 cents
Gas Blanketing Vent Size For Atmospheric Storage TankStarted by Guest_Fergie_* , 13 Apr 2026 |
N2 Blanketing To Gasoline Tanks With IfrStarted by Guest_NICOLAST_* , 20 Dec 2024 |
Tank N2 Blanketing FlowrateStarted by Guest_JakeHollier_* , 01 Oct 2024 |
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , 26 Apr 2024 |
Coefficient Of Conversion Of Electrical Energy Into Thermal Energy ForStarted by Guest_amx_* , 03 Apr 2024 |
