Co2 Freeze Out Check
Posted 10 December 2009 - 02:12 AM
I am working on simulation of LNG Plant. I have a De-Ethanizer which is operating under cryogenic conditions. I nedd to check CO2 freeze out on each tray. Hysys utility 0f "CO2 Freeze Out" works only for Streams and not for Trays. Is there any method to check CO2 freezing on Trays.
Posted 10 December 2009 - 02:50 AM
If you have concerns with respect to CO2 freezing, the best place to check are: feed streams to the De-C2 tower, and the overhead stream. There you can get CO2 freeze-up. If temperature of these streams is sufficiently above the solidification points of CO2, I can't see any issues in other locations in the tower.
http://www.bre.com/p...ation Paper.pdf
http://www.rivercity...p/CO2Freeze.pdf
Posted 10 December 2009 - 07:43 AM
'Zauberberg', on 10 Dec 2009 - 08:00 AM, said:
Thanks for the literature.Is this a turboexpander plant?
We have a propane chiller and then a low temp separator for condensate recovery. I have checked the feed stream and overhead stream. Temperature of ovhd gas from de-ethanizer is close to co2 freeze out temperature. I am working for worst conditions. I just wanted to know the co2 freezing temp on each tray if it occurs.
Posted 10 December 2009 - 09:27 AM
Just be aware of freeze prediction methods. Articles attached above are very illustrative.
Posted 10 December 2009 - 09:30 AM
Please let us know the actual CO2 content and the lowest temperature you have.In case of De-Ethanizer and propane chiller I consider temperature is not less than (-)35C if your gas stream has molecular weight in the range of 20-22, the CO2 Freeze-out temperature is in the range of (-)80 to (-) 90 Deg C.(Pure CO2 freezing temp is (-)78.3 Deg C)whereas If you have De-methanizer and temperature is say (-) 120 Deg C then you need to keep less than 50ppm of CO2 in feed gas.
As far as my experience of LNG simulation is concerned I have seen the limit of CO2 content in Amine Absorber Ovhd is as low as 7 ppm.
Posted 11 December 2009 - 07:56 AM
'Padmakar S Katre', on 10 Dec 2009 - 2:40 PM, said:
We have -90F lowest temperature and percentage of CO2 is 6.6%.Dear,
Posted 11 December 2009 - 09:23 AM
Could you just elaborate your scheme further. From where the DC-2 feed comes. As well give us the feed composition and de-ethanizer product specifications required. As it's not possible and even good to suggest you based on limited information you have given here.
Posted 13 December 2009 - 07:58 AM
http://www.ortloff.c...l/nglpapers.htm
![]() Strategy For Adequacy Check Of Multiple Bdvs In A SystemStarted by Guest_nabeelsp1036_* , 22 Jan 2025 |
![]() Wafer Check ValveStarted by Guest_Ali4269278331_* , 24 Apr 2024 |
Using Similar Check Valve In SeriesStarted by Guest_vsnlbom_* , 22 Dec 2023 |
Check Valve LocationStarted by Guest_sn_sn_* , 26 May 2023 |
