Articles Archives
Product Viscosity Versus Shear
Feb 11 2013 06:50 PM | Steve Hall in Fluid Flow
Many products are known to be “shear thinning,” which is a term given to materials that exhibit a decrease in viscosity when force is exerted. The viscosity of pseudoplastic fluids decreases with shear, and recovers quickly when the shear is removed. Examples include paper pulp in water, latex paint, molasses, and pharmaceutical suspensions (such as certain cough syrups).
Article Images:
Read story →    6 comments    ***--    product, shear and 3 more...
Statistical Process Control: Process and Qualit...
Jul 14 2012 06:50 PM | Chris Haslego in Process and Reactions
Statistical Process Control (SPC) provides a way to monitor chemical and other processes. We'll focus on continuous chemical processes and how the process and quality control departments utilize SPC. Process control engineers use SPC to monitor a process's stability, consistency and overall performance. Quality control engineers use SPC to see if the process is functioning within quality standards. In industry, these two departments work together to monitor a chemical process.
Article Images:
Read story →    3 comments    *****    spc, statistical, process and 3 more...
Water Chemistry and Treatment
Jun 03 2012 06:50 PM | Chris Haslego in Utilities
Water is a natural solvent. Rain water is acidic due to carbon dioxide picked up in the atmosphere. Water and CO2 make carbonic acid (acid rain). Water hardness is primarily calcium and magnesium. Calcium is limestone - common throughout Midwest. Acid water dissolves limestone, iron, and other minerals in soil.
Article Images:
Read story →    3 comments    ****-    water, chemistry, treatment and 1 more...
Why Become a Chemical Engineer?
May 30 2012 06:50 PM | Chris Haslego in For Students
How about a career where the opportunities are endless? Trying not to sound like an advertisement, I'd like to describe some of the more common careers pursued with a Chemical Engineering degree. Firstly, if you're considering studying Chemical Engineering, but you're a little timid because of the horror stories that you hear, you actually may want to think about it some more!
Article Images:
Read story →    3 comments    *****    why, chemical, engineering and 1 more...
Steam Tracing with MS Excel
May 24 2012 06:50 PM | adelange in Heat Transfer
Heat tracing is used to prevent heat loss from process fluids being transported in process fluid pipes, when there is risk of damage to piping, or interference with operation such as fouling or blockage, caused by the congealing, increase in viscosity, or separation of components, in the fluid below certain temperatures, or when there is risk of formation of corrosive substances or water due to condensation in corrosive services.
Article Images:
Read story →    3 comments    ****-    steam, tracing, calculation
Deaerators for Boilers
May 22 2012 09:54 AM | Chris Haslego in Utilities
Removing dissolved oxygen from boiler feed water is absolutely necessary to protect your boiler equipment from severe corrosion. But the make-up water necessary in any boiler system inevitably contains dissolved oxygen. Oxygen can sometimes enter condensate systems as well. A good deaerator is essential to trouble-free boiler operation.
Article Images: Attached Image: deaerator-1.gif Attached Image: deaerator-2.gif Attached Image: deaerator-3.gif
Read story →    1 comments    -----
Wine and Wine Making
Aug 02 2010 12:57 PM | Chris Haslego in Other Topics
Wine is fermented grape juice. Wine can be made from grapes, fruits, berries etc. Most wine, though , is made from grapes. And no matter what the wine is made from, there must be fermentation, that is, that sugar be transformed into alcohol. If the amount of alcohol is relatively low, the result is wine. If it is high, the result is a "distilled liquor," something like gin or vodka.
Article Images: Attached Image: WINE2.GIF
Read story →    0 comments    -----
U in Heat Exchangers
May 10 2012 08:19 AM | bspang in Heat Transfer
Typical values of U are useful for quickly estimating the required surface area. The literature has many tabulations of such typical coefficients for commercial heat transfer services.
Article Images: Attached Image: uexchangers1.gif
Read story →    0 comments    ****-
Valve Sizing and Selection
Dec 05 2011 03:20 PM | Chris Haslego in Fluid Flow
Sizing flow valves is a science with many rules of thumb that few people agree on. In this article I'll try to define a more standard procedure for sizing a valve as well as helping to select the appropriate type of valve. **Please note that the corr...
Article Images: Attached Image: valve1.gif Attached Image: valve2.gif Attached Image: valve3.gif Attached Image: valve4.gif Attached Image: valve5.gif Attached Image: valve6.gif Attached Image: valve7.gif Attached Image: valve8.gif Attached Image: valvechart.gif
Read story →    16 comments    ****-    valve, sizing, selection
Submission Received
Aug 24 2011 10:50 PM | Chris Haslego in Articles
Thank you for your submission. We've received your information and will be in contact with you shortly.
Article Images:
Physical Properties on the Internet
Jun 16 2011 09:50 PM | Chris Haslego in Physical Properties
Finding physical properties on the internet can lead to an interesting journey. Here, we've compiled a list of some of the best sites that we've found over the years. Thermodynamic and Transport Properties of Water and SteamDr. Bernhard Spang presents...
Article Images:
Read story →    0 comments    *****
Terms of Use and Legal Restrictions
Feb 17 2011 11:50 PM | Chris Haslego in Articles
ATTENTION: PLEASE READ THESE TERMS CAREFULLY BEFORE USING THIS WEB SITE. USING THIS WEB SITE INDICATES THAT YOU ACCEPT THESE TERMS. IF YOU DO NOT ACCEPT THESE TERMS ("TERMS"), DO NOT USE THIS WEB SITE. Use of Site. The Chemical Engineers' Resource Pa...
Article Images:
Mail List Subscribers: Join Our Community
Dec 30 2010 11:20 PM | Chris Haslego in Articles
I'd like to welcome our mail list subscribers to our improved community. For years, visitors to the site had a chance to quickly fill out a brief form at the bottom of every page on the site to let us know that they wanted to be updated when new conte...
Article Images: Attached Image: forgot_password_email_entry.gif Attached Image: password_email_sent.gif Attached Image: password_reset_email_with_link.gif Attached Image: reset_password_forrm.gif
ChE Plus Has Moved
Dec 29 2010 10:10 PM | Chris Haslego in Articles
ChE Plus has moved to the Community section of our website. Here, we'll explain how to access your ChE Plus files in our new interface. If you do NOT have an account set up in our community section, read below about how to gain access.Already Have a...
Article Images: Attached Image: alread_member_login.gif Attached Image: downloads_menu_item.gif Attached Image: cheplus_files_in_downloads.gif Attached Image: forgot_password_email_entry.gif Attached Image: password_email_sent.gif Attached Image: password_reset_email_with_link.gif Attached Image: reset_password_forrm.gif
Correlations for Convective Heat Transfer
Nov 08 2010 01:20 PM | bspang in Heat Transfer
In many cases it's convenient to have simple equations for estimation of heat transfer coefficients. Below is a collection of recommended correlations for single-phase convective flow in different geometries as well as a few equations for heat transfer...
Article Images: [attachment=5123:IPC]
Air Leak Testing Prior to Commissioning
Nov 08 2010 01:30 PM | Chris Haslego in Maintenance and Repair
Our message board is a constant source of great advice and information for all of our users. Some times, an especially useful discussion takes place that deserves a little extra attention. The inquiry and reply shownin this articlecan benefit process e...
Article Images:
Ammonia: The Next Step
Nov 08 2010 01:20 PM | Guest in Process and Reactions
Steam reforming of hydrocarbons for ammonia production was introduced in 1930. Since then, the technology has experienced revolutionary changes in its energy consumption patterns. Ranging from an early level of 20 Gcal/tonne (79.4 MBtu/tonne) to about...
Article Images:
Read story →    0 comments    ***--
Relieve Valve Set Pressures
Nov 08 2010 01:20 PM | pleckner in Safety and Pressure Relief
As the title of this column implies, I intend to present various topics related to Process Engineering Design based on my knowledge and experiences. I will convey what approaches I think you should be taking. I will stress "the correct way" so don't ex...
Article Images:
Relief Valves: "What Can Go Wrong" Scen...
Nov 08 2010 01:30 PM | pleckner in Safety and Pressure Relief
What can go wrong in a chemical facility? Plenty! A report in the August 2000 issue of CEP1 shows that operator error or poor maintenance was the leading of cause of accidents for unfired pressure vessels eight years running. The ProblemAccidents not o...
Article Images:
Rupture Disks for Process Engineers - Part 1
This is a real story. A rupture disk manufacturer presented a seminar to a group consisting of junior and more senior level process design engineers (yours truly included) with a few instrument engineers thrown in. After about an hour of hearing terms...
Article Images:
Read story →    1 comments    *****
Rupture Disks for Process Engineers - Part 2
Part 1 of this series on rupture disks for Process Engineers covered why you use a rupture disk and when you might want to use this device. This part will discuss how to size the rupture disk. Subsequent parts will include how to set the burst pressure...
Article Images:
Rupture Disks for Process Engineers - Part 3
Part 1 of this series on rupture disks for Process Engineers covered why you use a rupture disk and when you might want to use this device. Part 2 discussed how to size the rupture disk. In this part, I will cover how to set the burst pressure. Subsequ...
Article Images:
Rupture Disks for Process Engineers - Part 4
Part 1 of this series on rupture disks for Process Engineers covered why you use a rupture disk and when you might want to use this device. Part 2 discussed how to size the rupture disk. Part 3 discussed how to set the burst pressure. In this part, I w...
Article Images:
Rupture Disks for Process Engineers - Part 5
Part 1 of this series on rupture disks for Process Engineers covered why you use a rupture disk and when you might want to use this device. Part 2 discussed how to size the rupture disk. Part 3 discussed how to set the burst pressure. Part 4 discussed...
Article Images:
Rupture Disks for Process Engineers - Part 6
Article Images:
