Separator Sizing
#1 Three
Three
  • 5 posts
Posted 31 May 2016 - 03:08 AM
Hello all,
I'm currently generating an in-house procedure for the sizing of gas/liquid separators. I have plenty of resources for design calculations, system modelling and such, however I've run into a bit of a problem with separator selection. Obviously the separator has to be fit for purpose, a knockout drum probably won't be sufficient upstream of a compressor, but I can't find any literature which provides clear, concise and detailed guidance on selection of separator type (e.g. am I best with a horizontal van-type demister, instead of a cyclone?).
I've searched the forum and found some discussion on this, but nothing which seems to fit my needs. I've consulted colleagues who have said that in the past separator sizing has been done via experience, but for the sake of retaining and disseminating this knowledge in future I'd rather have some concrete references. I should mention that we are design house, so I only require rough guidance as opposed to precision calcs that vendors use, enough to generate a datasheet anyway. If someone could point me in the direction of some good literature that would be much appreciated.
Thanks in advance.
#2 Bobby Strain
Posted 31 May 2016 - 08:50 AM
Google my name to find my website. Check what is there. You will find lots of information through the links.
#3 Mahdi1980
Mahdi1980
  • 182 posts
Posted 31 May 2016 - 09:39 AM
I have attached two applicable documents for you.
hope these are helpful
Mahdi
#4 breizh
  • 6,349 posts
Posted 31 May 2016 - 06:01 PM
http://www.red-bag.c...sel-sizing.html
In addition to the  support from other members.
Edited by breizh, 31 May 2016 - 07:11 PM.
#5 Three
Three
  • 5 posts
Posted 01 June 2016 - 04:13 AM
All,
Thank you for the info, it's proven most useful.
