How To Convert Mm To % Of A Level Transmitter.
#1 aanita
aanita
  • 105 posts
Posted 10 June 2011 - 11:47 AM
In a horizontal steam drum,level transmitter LT measurement is given in P&ID by mm. Followinfs are the alarms setting given:
Measurement in mm In %
LAHH : 1250 mm ---- 96.2%
LAH : 1200 mm ---- 92.1%
NLL : 1050 mm ---- ?
LAL : 900 mm ---- 67.6%
LALL : 350 mm ---- 30%
My question is how can I convert NLL from mm to % of level?
Thank you .
#2 Zauberberg
Zauberberg
  • 2,728 posts
Posted 10 June 2011 - 02:50 PM
You need to take the vessel datasheet and see what is the total measurement span (distance between the connection nozzles) of the transmitter. Then, the calculation is straightforward: divide the NLL (in mm) with the total distance between the transmitter nozzles, and multiply by 100%. That is your NLL value expressed as percent.
#3 breizh
  • 6,735 posts
Posted 10 June 2011 - 10:53 PM
To support your query , Let you download Tankwin (freeware from Contrec)
http://www.contreceu.../downloads.html
Hope this helps
