while studying the centrifugal pump curve I came across a term 'shutoff head',can somebody please explain in detail what exactly does shutoff head mean?
Ashish.
Shut Off Head
Started by Guest_Guest_ashish_*_*, Sep 19 2005 01:55 AM
Posted 19 September 2005 - 01:55 AM
Posted 19 September 2005 - 02:10 AM
Shutoff head is the head developed by the centrifugal pump when there is no flow. So if you have the pump curve and look at the head developed at zero flow, that's the shutoff head of your pump.
Posted 19 September 2005 - 04:40 AM
in more practical way if u start centrifugal pump and close the discharge valve. u will get the maximum
value of pressure on discharge gauge. this pressure divided by density*gravitational constat g gives u
shut off head.
shut off head.
QUOTE (gvdlans @ Sep 19 2005, 02:10 AM) <{POST_SNAPBACK}>
Understanding Polytropic Head And Its Relationship With Gas DensityStarted by Guest_Kakka_* , 18 Dec 2024 |
![]() Discharge Head Or Differential Head, Pump CurveStarted by Guest_panoska_* , 11 Nov 2024 |
![]() Centrifugal Compressors (Actual Vs Polytropic Head)Started by Guest_panoska_* , 25 Oct 2024 |
![]() ![]() Reciprocating Pump Acceleration Head With Vertical Pipe LineStarted by Guest_Sansan_* , 18 Oct 2024 |
Shut Down ValveStarted by Guest_Ali4269278331_* , 20 Jan 2024 |
