Hello
i want to know about different types of steam. How many types and what is the difference b/w them , like saturate steam and super heated steam.thankyou
Types Of Steam
Started by kumaqal.engr, Dec 18 2005 07:43 AM
Posted 18 December 2005 - 07:43 AM
Posted 18 December 2005 - 08:45 AM
SATURATED STEAM
The steam which is at its saturation temperature i.e. vapors are in equilibrium with liquid at a given pressure is known as saturated steam. If you look the staurated steam tables you will see that for ever pressure there is a corresponding temperature at which the water boils and vapor and liqiuid are in equilibrium with each other.
SUPERHEATED STEAM
If you keep giving heat to a saturated steam at a constant pressure the temperature of the steam starts to rise and the temperature difference between the saturation temp at that pressure and temperature of the steam is the DEGREE OF SUPER HEAT of the steam.
Steam at a temperature higher than its saturation temperature (corresponding to pressure) is known as superheated steam . Again if you see the SUPERHEATED STEAM Tables you will see that there will be a number of of temperatures for a single value of pressure.
I hope you get the answer of your question.
Please correct me if I am wrong in any of my statement.
SUPERHEATED STEAM
Converting Superheated Steam To Saturated SteamStarted by Guest_addiesalsabil_* , 10 Sep 2023 |
![]() Steam Used In ReboilersStarted by Guest_aliebrahem17_* , 05 Jul 2025 |
Steam On Shell Side Of A Vertical HexStarted by Guest_Lyne_* , 09 Jul 2025 |
