I am an intern in a waste water treatment company. I have been given a task to review existing pH adjustment calculation prior to treatment. I find the calculation might not be accurate as there is no consideration of alkalinity of waste water in it assuming waste water should have higher alkalinity.
Example of scenario is pH adjustment of waste water from pH range of 6 to pH 11 using NaOH (48%).
The question now is, should I consider the alkalinity when calculating the chemical dosing, and if yes, how would be the calculation steps be (references, if any)?
Thank you.
