1. Normally our concerns is the heat flux as this figure shows whether we are safe or not at the ground level.
2. However, you can convert to temperature if you have the mass of the object, specific heat and emissivity (equal 1 for black body).
3. You need to assume the equilibrium temperature and determine the heat loss to surrounding (you need ambient temperature as well). Equate this heat loss with the heat flux. Yes... you also need to know the effective surface area of the object.
4. The heat transfer coefficient shall depend on the type of object. A circular object has difference equation from a flat object.
5. It shall be interesting if you can share you findings. You will be the first person to do it (CONGRATULATION)
Edited by S.AHMAD, 13 December 2013 - 02:04 AM.
