I have to calculate erosional velocity through a nozzle of a Flare knock out drum, does it have to be calculated the same way as we calculate for pipelines? can anyone refer me to any reference material?
mmairaja
Nozzle Sizing
Started by mmairaja, Apr 18 2006 10:07 AM
Posted 18 April 2006 - 10:07 AM
Posted 06 June 2006 - 04:52 PM
Hi mmairaja:
Here are two HTML files: calc5.htm and calc7.htm.
calc5.htm calculator is on the compressible flow and nozzle topics -- http://members.aol.c...gware/calc5.htm, while calc7.htm is for the ideal gas equation to help you with the density calculation -- http://members.aol.c...gware/calc7.htm.
In the end, for the given mass flow rate, you will get the cross sectional area value.
Use your input values and try to get some reasonable output values. If you get stuck, let me know.
Thanks,
Gordan
Thanks,
Gordan
Flash Steam Vessel SizingStarted by Guest_JohnFields343_* , 24 Apr 2024 |
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Barometric Legs Line SizingStarted by Guest_panagiotis_* , 17 Mar 2023 |
Sizing Of Vertical/horizontal Flash DrumStarted by Guest_Mohammad3799_* , 10 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
