The Position Of The Expansion Tank
heat transfer; expansion tank process engineering
#1 chendoggie87
chendoggie87
Posted 13 November 2014 - 04:47 AM
Hi All,
Is there any requirement to install the expansion tank at the level higher than the boiler/ heat exchanger? If yes, what is the specification or standard to follow when design the expansion tank (the height difference between the expansion tank and boiler/heat exchanger)?
Your input to this issue will be highly appreciated. =)
#2 fallah
  • 4,955 posts
Posted 13 November 2014 - 11:54 AM
If you search this site, you will find a lot of useful technical matters about your query...
