Minimum Flow For Positive Displacement Pump
#1 Takechi
Takechi
  • 43 posts
Posted 30 September 2018 - 02:02 AM
Dear all expert
When I see the performance pump curve, I cannot see the mimumum flow line of positive displacement performance pump curve.
Does positive displacement pump require minimum flow for protect temp rising or vibration? Why?
Sapao
#2 fallah
  • 5,019 posts
Posted 30 September 2018 - 04:25 AM
Sapao,
No, because a PD pump is a constant flow machine. To protect downstream piping /equipment against high pressure a PSV is applied at pump discharge line.
#3 Takechi
Takechi
  • 43 posts
Posted 30 September 2018 - 10:41 AM
Fallah
Gear pump or screw pump also the same, right? It does not require minimum flow.
Salapao
#4 fallah
  • 5,019 posts
Posted 30 September 2018 - 01:10 PM
All PD pumps...
#5 farid.k
farid.k
  • 384 posts
Posted 11 October 2018 - 11:38 PM
But pd pump has recycle line that has backpressure regulator in order to make sure the system will not over pressure. It act just like minimum flow line. The difference is minimum flow line to protect pump to not operate the below minimum flow line, but pd pump is to protect to not over pressure at discharge side. Both line normally will go back to reservoir
Edited by farid.k, 12 October 2018 - 10:48 AM.
#6 Takechi
Takechi
  • 43 posts
Posted 13 October 2018 - 08:00 AM
Thanks for you sharing Fallah, farid.k.
#7 breizh
  • 6,775 posts
Posted 13 October 2018 - 08:25 AM
Probably good to read this article:
https://www.pumpindu...au/pump-school/
