I posted this over at Eng-Tips, but didn't get any bites yet, so I thought I would give it to you guys to chew on.
The NBBI Rules and Recommendations for the Design and Construction of Boiler Blowoff Systems (1991) shows an orifice in the discharge line from a blowoff tank and gives criteria for calculating the orifice size. However, the purpose of the orifice is never discussed. Can anyone explain the purpose of this orifice? I don't like folowong code calculations by rote without understanding the engineering philosophy behind them.
Thanks,
Mike
Boiler Blowoff Tank Drain Orifice
Started by Guest_mvancleave_*, Oct 17 2006 11:48 AM
#1 Guest_mvancleave_*
Posted 17 October 2006 - 11:48 AM
Posted 18 October 2006 - 07:41 PM
Are you talking about the continuous (or semi-continuous) blowdown from the top skimmer of the boiler?
I ran into this same confusion. I think that it is a cook-book method for generating a specific amount of flash steam at a given pressure. If you are not recovering the flash steam I don't think that it matters. But if you want to recover a specific pressure flash steam thats when I think that orifice sizing becomes an issue.
I might be wrong, but that is my best guess after pondering it a while when I had the same question.
Note: If you are installing a continuous blowdown controller, be sure to install it strictly by the manufacturers recommendations. The sonductivity probes can be mighty picky.
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , 26 Apr 2024 |
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
Closed Drain SystemStarted by Guest_Falah_* , 26 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
Asme Code For Fiberglass Pressure Tank FeaStarted by Guest_Pheeto_* , 13 Feb 2024 |
